Enables a TRACE on any port by prompting the selection on the console during boot up. This allows the user start trace for debugging earlier on specified port. Works on console connection only. The default is disabled.
Important
Do not change this parameter unless directed by Technical Support.
enable
configure terminal
boot config flags debugmode
